processing dgn error f_67(CreationFactory)
  • Aug 14, 2018 4:39 PM UTC
  • 59 views
My workflow successfully read in the 600,000 dgn features, ran through a Matcher transformer to eliminate duplicates, was going through a featuremerger and geometry filter where it bombed as it was writing to shapefiles. The error -
f_67(CreationFactory): Error - Number of measures found on the 'line/path' geometry did not match features number of coordinates
I have my Reader set to Master coordinate units. Has anyone seen this error and is there either a setting or some other filter/transformer that can be added to fix this?
I'm reading MicroStation V8, processing in FME 2017
danilo_fme
Forum|alt.badge.img+58
  • Aug 14, 2018 10:14 PM UTC
Hi @tsurveyor
Could you share us your log file?
Thanks,
Danilo
  • Aug 16, 2018 3:59 PM UTC
fme-failure-20180813.pdf
I can't find where the translation log is saved, but I did copy paste the info into Word before closing the program. I have attached a pdf with all the log info. Sorry for the delay, got caught up in another project.
  • Aug 16, 2018 4:00 PM UTC
Hi @tsurveyor
Thanks,
Danilo
@danilo_fme I finally got it uploaded.
