Problems to write field date in Postgis Database
  • Sep 5, 2018 12:42 AM UTC
  • 121 views
mr_fme
Forum|alt.badge.img+9
I would like some features in PostGis database, there is one field called 'dt_desc' with the value (2018-09-04 19:00:20).
But the WARN messege showed in my log: 'dt_desc' cannot be convert to timestamp, and none features is recorded.
I tried change the format in FME writer to timestamp, varchar, date...but the problem continue again
In my PostGis database the format for this field is timestamp.
Somebody can help me?
Thank´s
Best answer by takashi
Hi @mr_fme, try formatting the datetime value with the Standard FME Date/Time Format (i.e. %Y%m%d%H%M%S) before writing.
Generally FME automatically converts a date/time string with the standard FME date/time format to an appropriate value according to the destination data format - PostGIS in this case.
  • Sep 5, 2018 1:09 AM UTC
