When I try to save a database connection. In Tools -> FME Options -> FME Database Connection. The dialog is displayed: Unable to Store Connection.
Can anyone tell you why this happens?
Try to test the database connection, is it succesfull?
  • Try add the connection by adding new reader and define the connection parameters , then check In Tools -> FME Options -> FME Database Connection you will find your connection.
  • Any database connection you add by using reader option it will appear under FME Database Connection .
If it's not working with you do the following >>>
  • Try to run FME desktop as admin (Run As Administrator)
Thank you Guys.
My customer solved this problem in the other way.
Thank´s
Thank you Guys.
Thank´s
How did you solve this problem? I'm facing the same issue and the below solutions didn't work for me.
Hi @anjalikolath, I think, since the solution in this thread didn't help in your case, it might be a good idea to post your scenario as a New question, and provide some more details on what you've tried, and what are the outcomes. This might help you get more suggestions most relevant to your issue.
