Problem with Date fielf in Open API Writer (Fgdb()
  • Feb 15, 2024 8:44 AM UTC
  • 5 replies
  • 94 views
fme_dr22_forum
Forum|alt.badge.img+5
I have a problem writing a date field in a Filegeodatabase (open API Fgdb Writer)As soon as I enter these date fields manually, nothing is put in the Fgdb.In the attribute creator I enter @DateTimeFormat(20240101,%d-%m-%Y) so this should work.What can I do to make this work?
hkingsbury
Forum|alt.badge.img+73
  • Feb 15, 2024 7:08 PM UTC
That should work. I wonder if there is something else going wrong. Are there any warnings or errors in the Translation Log?
fme_dr22_forum
Hello hkingsbury,
Thank you for your reaction. No, FME does not give any error messages. Or could it be that the time/date of our system is not set correctly? I live in the Netherlands. Time zone on our system is (UTC+1:00)
I have set the attribute creator like this (date field: beginGeldigheid)
hkingsbury
  • Feb 18, 2024 9:21 PM UTC
What version of FME are you using? It’s working fine for me in 2023.1
See an attached example
fme_dr22_forum
We are using version FME 2022.2.6.0 (20230523 - Build 22800).Seems to be a little older than the version you have.I haven't been working with FME for long. How can I open the attached example? I now get the following and I don't know how to link the creator to my dataset.
hkingsbury
  • Feb 19, 2024 7:15 PM UTC
Not to worry, ignore that attachment. Can you try removing the DateTimeFormat function and running it again with the value ‘20240101’ (in your original workspace, not the one I posted)
Slight tangent explaining the screenshot
Transformers have versions, and between workbench/form versions, these will sometimes get updated. You would’ve got some sort of warning about opening a newer workbench in an older version of FME. There should be an attribute creator in between the creator and writer. This indicates that the version of the creator and the writer is the same in 2022.2 and 2023.1 but the attribute creator has been updated between those versions, so the older version can’t find it
