Problem to connect transformer S3ObjectLister
  • Jul 3, 2017 8:38 PM UTC
  • 6 replies
  • 64 views
danilo_fme
Forum|alt.badge.img+58
Hi FME user's,
My customer doens't connect the transformer S3ObjectLister. I maked the test in my machine and company and the results is OK, all files are display.
I believe my customer wants to contact the IT Team to disable any port.
Attached the log file.
Thanks in Advance,
Danilo de Lima
Best answer by geosander
Hi @danilo_inovacao,
Are you sure that your customers machine (where FME runs ons) also has access to the S3 bucket? You need to make sure that your customer (e.g. a single static IP or an IP range) has READ access to it, else the objects can't be listed by any application, including FME. The secret key and the access key alone might not be enough.
Have a look at the security policy settings on the AWS console. Here are some examples.
It should not be necessary to open all ports, as the standard ones are used.
geosander
Forum|alt.badge.img+7
  • Jul 3, 2017 10:14 PM UTC
  • Jul 4, 2017 7:30 AM UTC
Also check the proxy settings in FME: If they're using a proxy to connect to the internet, they'll need at least FME 2017, see also: https://knowledge.safe.com/questions/31838/s3uploader-and-network-proxy.html
geosander
  • Jul 4, 2017 8:59 AM UTC
Yeah, that's a good one!
danilo_fme
  • Jul 4, 2017 12:26 PM UTC
Hi @sander_s and @david_r thanks for support. :)
My customer has installed the FME 2016 now.
danilo_fme
  • Jul 4, 2017 4:57 PM UTC
thanks @david_r
darkspatiallord
Forum|alt.badge.img+8
The proxy settings in 2016 wont help you. you will need to get IT to open the correct ports to enable access out and in to s3.
Many locations have this access disabled by default
