Prevent MongoReader from skipping attribute
  • Aug 17, 2018 12:35 PM UTC
  • 54 views
As beginner with FME, I try to read documents from MongoDB.
As far I understand, as a defaut behavior, if an attribute is not detected in the first read documents, its reading will be skipped. Is there any way to avoid this behavior?
Many thanks!
jakemolnar
Have you tried setting the parameter "Read Original JSON Document" to "Yes"?
This will populate the
mongodb_json
attribute, which will have all of the information contained in the original document. You can split this into individual attributes with a JSONFlattener transformer.
  • Aug 21, 2018 9:01 AM UTC
Dear @jakemolnar,
Many thanks for your answer. Yes, this approach is the workaround implemented. Is there any way to get attributes directly read by MongoReader?
