Preserver lines from change after saving to a new DWG
  • August 6, 2025
  • 63 views
probert1968
Forum|alt.badge.img+5
Hello !
I have a DWG that has a different type of feature that I cannot convert to ArcGIS Pro because it does not recongize it or unable to keep it preserve the line..
This is an oiginial DWG I have here :
After I save them to a new DWG with set to ESPG 26913.  I got this
It looks like a feature change for line from an oroginal to a new one above the picures here…
Is there a way for me to preserve the lines from  change it ?
Thanks
jobvdnoort
Forum|alt.badge.img+13
  • August 7, 2025
What do you get when you read your original file with a Featurereader?
Dataset should be your file.
Can you show the inspector after you run this?
Kr,
Job
probert1968
  • August 7, 2025
Actually, I use the FME Data inspector to selected them because of the different coordinate system to our projected system.  When I review the arcshape  to ArcGIS Pro , it does not what I want.
So that is why I put out my question to see if there is a way around.
BTW, thank you. I will test it and let you know if this gets right.
probert1968
  • August 8, 2025
@jobvdnoort ,
Didn’t work and don’t know why however, i looked it up transformer list and found one that worked for me. .  ArcStoker is what I neeed to correct the zigzag.
