PostgreSQL Query - Never Times Out
jbradfor
Forum|alt.badge.img+7
We use a PostgreSQL connection to access our GreenPlum environment to execute a SQL statement to pull non-spatial point data. Normal Query runtime, runs fine.
When the tables involved in the SQL are under heavy load, the query slows down a lot. It then NEVER returns anything and will continue to run until we stop it.
So, my question is. When we setup connections in FME desktop, is there any way to setup a MAX connection timeout or Query timeout?
fmelizard
Forum|alt.badge.img+19
  • March 20, 2018
Hi @jbradfor, if you're able to use an SQLCreator or SQLExecutor, you might be able to set the timeout there
set statement_timeout to 100;
jbradfor
  • May 3, 2018
I was able to get this to work.  Thanks.
FME_SQL_DELIMITER ;
set statement_timeout to 1800000;  --30 min
select distinct...
