postgres writer inserts 0 instead of actual value
istvanv
Participant
I got a workspace that I run and as an output it creates one row with statistics.
If I run the workspace the output is correct both with inspector and the row written to postgres.
If I use another workspace with a workspace runner to run the workspace for multiple areas, one of my column values is 0 in every row.
Any thoughts?
erik_jan
Forum|alt.badge.img+19
  • June 17, 2020
0 is probably the default value for the attribute in the table.
So, could it be that the attribute does not get a value (or not a valid value: char instead of number) if you run it for multiple areas?
Hope this helps finding the issue.
istvanv
Participant
  • Participant
  • June 17, 2020
my last row is running the workspace manually the rows before that are when it's being run with a workspace runner. the tables are being created by me, and i haven't set any default values,
