Possible file path or filename problems for FME Server
  • Apr 15, 2019 3:54 PM UTC
  • 224 views
jhu_20
Forum|alt.badge.img+12
I received the following error message when running the job on FME server (2018.1). But this problem does not happen when running on FME desktop (2018.1). Any suggestions ? I suspect that the problem may be the path reading issue for FME Server. The filename and path works when checking in window explorer. Thank in advance for all help.
Error in the Kingdom Well Reader engine: The file could not be found.: G:\\SMT\\1 Production Projects\\Barnett (SQL Server)\\SMT_Barnett\\SMT_Barnett.tks
Best answer by hollyatsafe
Hi @jhu_20
In FME Server we recommend referencing a directory or file using the UNC path: https://knowledge.safe.com/articles/376/workspace-fails-using-fme-server-data-in-mapped-dr.html.
Also please ensure that the account running the FME Server Services has full permissions to this file location.
  • Apr 15, 2019 7:53 PM UTC
Hi @jhu_20
jhu_20
  • Apr 15, 2019 7:55 PM UTC
Holly,
Thanks for your response. I can confirm that changing from mapped drives to UNC path resolved the issue.
  • Aug 15, 2019 2:22 PM UTC
Path Copy Copy is a great tool for windows for getting the UNC path for any file direct from the context menu
