Populate File Geodatabase Attribute with default value
  • Feb 5, 2020 5:36 PM UTC
  • 7 replies
  • 217 views
ostoja
Forum|alt.badge.img+9
My target ESRI File Geodatabase (FGDB) is following UPDM 2019 data model. By that, we have few feature classes which contain many subtypes. Many feature class attributes have defined default values on the level of the FCL subtype (AssetGroup) usually in combination with domain.
What I noted is that default value of the attributes not contained in the FGDB writer is not populated in the target FCL. We have huge number of attributes on the FCL level and it would be quite some work to pick up each default value and set it up in the writer. Maintaining such workbench would be also quite demanding.
Can someone please tell me is it possible to get somehow the default value of the attribute automatically populated in the FGDB like when manual editing in ArcGIS Pro? I am using FME 2019.2 with ArcGIS Pro 2.4.
Thanks in advance,
Dušan
mhab
Forum|alt.badge.img+10
  • Feb 6, 2020 10:29 PM UTC
It seems pretty clear, that FileGeoDB writer doesn't handle default values properly.
It seems for a NOT NULL field always default 0 is used instead of the predefined default value.
Now I tried a workaround by using a Schema Reader, but I was not able to get as deep in the schema info as to read the predefined default values.
Any ideas how to get a more complete schema definition, which also provides predefined default values for a field ?
Thanks
Michael
ostoja
  • Feb 7, 2020 10:29 AM UTC
Thanks
Michael
For the moment, only solution which I see as achievable is that we introduce a PythonCaller which will through ArcPy pick up all attributes with default value and initialize them. Of course, possibility to define default value on the FCL value as well as on the subtype level is making things a bit complex, but I assume this is possible.
Nevertheless, I do not understand why would FGDB Writer ignore attribute’s default value.
Forum|alt.badge.img+54
  • Feb 7, 2020 10:39 AM UTC
Does it make any difference if you use a template file? (I don't have access to ArcGIS to check)
ostoja
  • Feb 7, 2020 10:53 AM UTC
I tried to use a XML Template File, but FME complained that target schema is already existing and stopped the migration.
I didnt tried to use FGDB as a template because in that case, if I do not make a mistake, I would have to owerwrite the target database.
bwn
Forum|alt.badge.img+26
  • Feb 7, 2020 12:13 PM UTC
My thoughts were the same as @ebygomm : Use a blank FDGB as a Template with the Field Default Values set using ArcCatalog.
Tested with the FileGeoDB Open API Writer. It works: Any new Features added are assigned the Default Field Value if no value otherwise set by the Writer.
To use:
  • In the Writer, set the path to the FGDB you wish to create. Make this a new FGDB that doesn't exist
  • In the Writer Parameters, turn On "Overwrite Existing Geodatabase"
  • In Template File Geodatabase, select the path of the Template FGDB
This does not overwrite the Template FGDB. It takes a copy of it and uses it to create and write to a new FGDB.
Since it appears you already have the Schema in a Geodatabase, then a Template FGDB can be created easily enough by using the "Copy" ArcTool in ArcGIS. This copies everything from a source GDB to a new template FGDB: Domains, SubTypes, Default Field Values, Indices etc. (although I would probably drop the indices in a template FGDB)
To "blank" the tables back to zero records in the Template FGDB, use the "Truncate" ArcTool.
ostoja
  • Feb 14, 2020 9:56 AM UTC
To use:
Thanks for your test @bwn
I tried your workflow with the Open API Writer and indeed the features went inside, but there is no data validation option on the Open API Writer so I cannot be 100% sure if the data written are correct.
Nevertheless, I wanted to check data written in the target FGDB, but as soon as I open FGDB in Catalog panel of ArcGIS Pro, software takes in some half minute complete available memory of the PC (it reaches ca. 26GB) and crashes before the table content is opened. I have no idea what is actualy written inside the FCL.
Can you please tell me are you using ArcGIS Pro or ArcMap to check the written data? It can happen that FGDB created by FME from the template file cannot be red by the Pro. @markatsafe mentioned me in one of my posts that upgrade to Arcobjects 11 will not be full implemented before FME 2020. Maybe ArcGIS Pro crash which I experienced is a consequence of this ArcObjects vs ArcPro SDK mismatch...
I also tested the template file option with the Geodatabase Writer, but there I receive the same error as without template file.
bwn
  • Feb 14, 2020 10:58 AM UTC
For testing, limit the number of features written to start with to say 100 using the Sampler Transformer. This is to test that default values are being created in FGDB fields with a Default value set.
If Pro is having problems, the written FGDB can be read back into FME to check that default values got created and viewed in an FME Inspector. On the FGDB Reader used to check a sample of Features, a limit can be set as to the maximum number of Features to read. Again this is just for testing that default values did get created by the Writer.
An alternative viewer to FME is QGIS.
Can't say why Pro would have problems. It should be able to deal with regular FGDBs fine, but can depend on the data within it.
