PointCloudExpressionEvaluator producing string column
  • Mar 28, 2019 10:15 AM UTC
  • 79 views
txalaparta
Forum|alt.badge.img+3
Hello
I am trying to create a point cloud with a string column. The value of the component depends on the value of another component. I am using PointCloudExpressionEvaluatot but this doesn´t allow string components.
I could use PointCloudComponentAdder to create string components but it doesn´t work because it creates constant strings which is not what I need.
For example:
If I have the following PointCloud:
x|y|gid|col0|col1
2653000|2565400|147729036548|0|255
2654000|2565400|147729036548|0|12
I´d like this output
x|y|gid|col0|col1
Replacing 255 with empty string
I am using FeatureReader and String concatenator but it´s very slow for about 200millionpoints
Any help woud be appreciated
Thanks
Oskar
Best answer by daveatsafe
Hi @txalaparta,
Please read the source XYZ file with col1 defined as uint8, then use a PointCloudFilter to separate the 255 points into their own cloud. The filter only accepts numeric values. You can then use a PointCloudComponentRemover on that cloud to remove the col1 component.
Send the Unfiltered cloud to a PointCloudComponentCoercer to coerce col1 to String. Send both clouds to a PointCloudCombiner to join them again. Because the 255 cloud has no col1 component, those points will have the default for String added, which is blank.
daveatsafe
Forum|alt.badge.img+24
  • Mar 29, 2019 11:52 PM UTC
Hi @txalaparta,
txalaparta
  • Mar 30, 2019 10:54 AM UTC
Hi @txalaparta,
Yes!!! This does exactly what I wanted
Thanks so much
