Point Cloud Precision
  • May 25, 2016
  • 127 views
mrclaudepicard
How can I set the precision for individual points in a point cloud?
After applying a 3D Rotation on my point cloud, I end up with x and y values with a precision of 13 and 14 digits, when my source has only 6 digits. I've used a PointCloudCoercer to get individual points that I can then pass through a CoordinateRounder before recombining them with a PointCloudCombiner.
It works, but the process is much longer than before.
Forum|alt.badge.img+5
Hi @mrclaudepicard
Sadly the CoordinateRounder doesn't (yet) work on point clouds. However, you can use the PointCloudExpressionEvaluator as a workaround.
In that transformer's dialog set the component to X and Data Type to Preserve. The Expression to round to three decimal places will be:
( floor( @Component(x) * 1000.0 ) / 1000.0 )
For six places it would be:
( floor( @Component(x) * 1000000.0 ) / 1000000.0 )
Of course, you also add similar entries for the Y and Z coordinates.
Hope this helps.
  • April 11, 2018
hi
This workaround will only narrow down number of decimals but ending zeros will be lost.
If i need to keep/retain number of decimals in point cloud writer (445566.70), how can that be done?
