Performance Issue is SDE geodatabase
  • January 18, 2013
  • 5 replies
  • 30 views
 I am using ARCSDE geodatabase as inputs to the workbench, from the input tables I need to extract the coordinates(x,y) values for point features and for linear linear feature i need to extract every vertex id's of the element(line segment) along with x, y coordinates of each vertex and "from junction element id" & "to junction element id" of the element. To extract the geometry information FME takes lot of time. Time consumption is the major hurdle in this project. It is the chalenging issue to succed in our project. Please help us that how to increase performance.
Thanks in Advance,
Seshu
Best answer by fmelizard
This video demonstrates ways to improve reading from spatial databases.
http://www.youtube.com/watch?v=77eUreTtrZo
Hope this helps,
Itay
  • January 18, 2013
It is not very easy to give specific hints when there is so little information to work with, but do you know whether it is ArcSDE or FME that is the bottleneck in your process? If not, I would suggest that as the first thing to find out.
David
fmelizard
Forum|alt.badge.img+21
  • January 18, 2013
Hope this helps,
Itay
  • January 19, 2013
HI Itay, Thanks for giving response. I have gone through the video but it is not clearly visible. Could you please send the video wih better visual clarity.
fmelizard
  • January 20, 2013
Hi Seshu,
You can donwload the video (google download youtube videos) and watch it locally.
Hope this helps,
Itay
  • January 23, 2013
Thanks..
