Performance disparity of Oracle Non-Spatial Reader on high-latency network
  • Jun 17, 2021 1:03 AM UTC
  • 151 views
paulot
New to FME and befuddled by the performance disparity of Oracle Non-Spatial reader over high-latency network links. Needless to say, I understand the benefits of having FME close to the data, but…
I compared the performance of the Oracle Non-Spatial reader against a CSV export from Oracle SQL Developer of the same database view on various machines in various locations on our network. The size of the fetch was 46394 database rows with just 8 columns.
From a desktop machine in the data centre close to the source Geodatabase:
SQL Developer CSV Export:             8m16s
FME Desktop Reader:                       10m11s
From a remote desktop machine on VPN:
SQL Developer CSV Export:             8m50s
FME Desktop Reader:                       72m
Remote FME Server:
FME Server Reader:                           32m9s
The most interesting fact is that the SQL Developer export suffered almost no performance impact even when it was executed over a high latency network link whereas the FME reader was devastated.
Here is a Wireshark capture of the network packets of the remote desktop machine over VPN:
When running a CSV export with SQL Developer, the database server sends large 1360 byte payloads back to back and the client machine only needs to acknowledge occasionally.
Wireshark SQL Developer
The equivalent fetch from FME Desktop seems to be endlessly handshaking with the database server using small 172-175 byte packet payloads and only occasionally receives a large 1360 byte data payload:
Wireshark FME ReaderAnyone else more familiar with FME Oracle readers and SQL*Net experience this kind of network behavior? What data transfer optimization is SQL Developer taking advantage of that FME Reader isn't?
Oracle SQL Developer 18.1.0.095
Oracle SQL*Net 18
Oracle Database 12.1.0.2
FME Desktop 2019.0.2/Win10
FME Server 2019.0.2/Win Server 2019
Best answer by paulot
My solution was to put my query into a view and switch to the ESRI Geodatabase reader. Just because I'm new, I hadn't seen that reader before, but of course it handles all the ST_Geometry work without a BLOB apparently. :)
paulot
  • Jun 17, 2021 3:50 PM UTC
Actually, I think I've tracked it down to the conversion of the ST_GEOMETRY field in the database using SDE.ST_ASBINARY(OHLINE.SHAPE) AS SHAPE_WKB in the query's select statement. This creates a BLOB column. I also tried ST_ASTEXT, which creates a CLOB column and still had slow performance. When I remove the field from the query, the FME reader is as fast as my CSV Exports with SQL Developer.
As I understand it, FME cannot read ST_GEOMETRY and this is the standard way to extract the shape field?
Forum|alt.badge.img+54
  • Jun 17, 2021 4:37 PM UTC
When you export as csv from SQL developer you just get the word (BLOB) don't you? So you're not actually getting the geometry at all
paulot
  • Jun 17, 2021 5:07 PM UTC
Yes, you're right. The CSV export from SQL Developer doesn't read the BLOB which is another confirmation that the BLOB is the issue.
paulot
  • Jun 18, 2021 12:02 AM UTC
