Parameters into log file
  • Nov 28, 2012 6:46 PM UTC
  • 6 replies
  • 163 views
lpalli
Forum|alt.badge.img+10
How to log into the log file, not only on the Workbench log window, the workspace parameters used to start it?
  • Nov 29, 2012 9:19 AM UTC
Kathy is correct. In FME 2012 you will usually find it on line 7 (or thereabouts) in the log file.
David
nic_ran
Forum|alt.badge.img+20
  • Nov 29, 2012 3:39 PM UTC
The TCLCaller can be used to write non-published params.
sigtill
Forum|alt.badge.img+25
  • Dec 3, 2012 7:37 PM UTC
Also the PythonCaller can be used to publish all avalaible Published Parameters. More information here: http://fmepedia.safe.com/articles/How_To/Startup-and-Shutdown-Python-and-TCL-Scripts
kimo
  • Dec 4, 2012 3:41 AM UTC
I went looking for the parameters in my log files too, and they are not there, only in the interactive window. Maybe there is a parameter setting?
What is required is a way of getting all the parameters so that they can be used to create a batch file. I wanted a dozen of them, and I didn't want to run each workbench to get them in the interactive window.
lpalli
  • Dec 4, 2012 9:05 AM UTC
Thanks for the answers.
I tried the Startup script proposition and I'm able to log the parameters.
But all the parameters are returned in the FME_MacroValues global variable: published parameters, private parameters, ...
Any idea on how identify and log only the published parameters?
Another "small" problem is that the password are also present int the FME_MacroValues dictionary and it's in plain readable format. How identify a password parameter to avoid logging it?
lpalli
  • Dec 6, 2012 8:47 AM UTC
Finally I created a small Startup Python Script to log the Published Parameters also in the log file, the only limitation of this script is that I must add manually the list of parameters to publish to prevent to publish all the parameters, also the not published!
import fmeobjects
## Script to log the Published Parameters also in the log file, not only in the
## Translation Log Window.
## The list of ordered parameters to log must be manually adapted to the
## parameters of the workspace.
# Odered list of Published Parameters to be logged
parameters = ["DatabaseId", "DestDataset_FILEGDB", "abc"]
logger = fmeobjects.FMELogFile()
logger.logMessageString("Published Parameters:", fmeobjects.FME_INFORM)
keyValue = "    --{0} {1}"
notDefined = "    --{0} not defined (the parameters list into the Startup " + \\
    "Python Script must be corrected)"
for parameter in parameters:
    if parameter in FME_MacroValues:
        logger.logMessageString(keyValue.format(parameter, \\
            FME_MacroValues[parameter]), fmeobjects.FME_INFORM)
    else:
            notDefined.format(parameter), fmeobjects.FME_WARN)
