Output data to local drive
  • Feb 6, 2013 2:43 PM UTC
  • 70 views
I have a job which has been added to FME Server. I would like a user to log into FME Server and run the workspace but allow them to process a textfile on their local drive and output a shapefile to their local drive also. The workspace connects to Oracle Spatial to retrieve some data also.
Is this possible?
Thanks
Best answer by sigtill
I assume you do not want to upload and download the file then? The only think that comes to my mind is to have a network share (on your computer) that FME Server and you have access to, and that you use the UNC-path as reference in the workspace when running it. Do you have a common place that both you and FME Server can access?
sigtill
Forum|alt.badge.img+25
  • Feb 8, 2013 6:05 AM UTC
