Hi @jugoslaviaa
Could you share us the complete Log File?
Thanks,
Danilo
danilo_fme wrote:
Hi @jugoslaviaa
Thanks,
Danilo
Hi @danilo_fme,
Even thought error message says about the log file, I am not able find it. At least, it has not been stored in the path i have given in the Work Space Parameter - Logging - Log File. I will come paste the entire error message I do get here . I have added the dataset in the question if it is any help.
--Error Message--
Creating reader for format: OpenStreetMap (OSM) Protocolbuffer Binary Format (PBF)
Trying to find a DYNAMIC plugin for reader named `OSMPBF'
Loaded module 'OSMPBF' from file 'C:\\Program Files\\FME\\plugins/gdal/GDAL.dll'
FME API version of module 'OSMPBF' matches current internal version (3.8 20170315)
OSMPBF reader: file 'G:/osm-centerline/paris_export.pbf' is invalid for this format
Failed to obtain any schemas from reader 'OSMPBF' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
FME Session Duration: 0.1 seconds. (CPU: 0.1s user, 0.0s system)
END - ProcessID: 13944, peak process memory usage: 56880 kB, current process memory usage: 40868 kB
Program Terminating
Translation FAILED.
Workspace generation failed. Parameter file was C:\\Users\\FME\\AppData\\Local\\Temp\\FME_155066218063_17372.
Thanks in advance.
jugoslaviaa wrote:
Hi @danilo_fme,
--Error Message--
Program Terminating
Translation FAILED.
Thanks in advance.
I tried renaming the file paris_export.osm.pbf, i.e. changing the ending to .osm.pbf, then it works just fine. Not sure why FME seems to be picky about the .osm.pbf-ending, but that seems to be the issue. Let me know if this works for you!
jugoslaviaa wrote:
Hi @danilo_fme,
--Error Message--
Program Terminating
Translation FAILED.
Thanks in advance.
Hi @jugoslaviaa
Thanks your data. When You open de Reader OpenStreetMap (OSM) Protocolbuffer Binary Format (PBF) the FME waits the extension *osm.pbf
Please, rename your extension for .osm.pdf, and the results are OK.
Thanks,
Danilo
Yes,it works! Thank you very much. Now I have to find out how I can extract the other_tag information from the file!
Best
@danilo_fme,
One more question, if i open this pbf (lines) file in QGIS, I see other_tag attribute. However, it does not appear after FME read the data. Do you have any idea what the reason may be? Or should i ask this one seperately? Thanks.
Best
Excellent! I'm happy to help you.
