Oracle Writer - Error Message
  • Aug 2, 2013 10:49 AM UTC
  • 9 replies
  • 114 views
Hello!
Writing to an Oracle Spatial Database I get following error:
Oracle Writer: Abnormal channel cleanup required, likely due to previous error
What could be the problem?
Thanks for your help, regards
Isabell
Best answer by fmelizard
Hi @isabell, please check out Oracle writer issues, WARN | Abnormal channel cleanup required for more information/answers regarding this WARN message in FME.
  • Aug 2, 2013 11:26 AM UTC
is that the only error message in the log? Or do you also get an ORA-XXXX error message? If so, please post it.
If this is the only error, you might want to forward it to Safe. I have the impression that the error is from FME, not Oracle directly.
David
  • Aug 2, 2013 11:32 AM UTC
Hey David!
No I don't get an ORA-XXX error message, so I have the problem, that I don't know exactly what is happening here.
You mean, I should send the logfile to SAFE?
Regards
Isabell
  • Aug 2, 2013 1:21 PM UTC
Hi Isabell,
yes, you can submit your error and attach you workspace and log file here: http://fmepedia.safe.com/knowledgeSubmitCase?
David
  • Aug 5, 2013 6:27 AM UTC
Thank you for your help!
I found the error!
Isabell
  • Jun 30, 2014 10:43 AM UTC
I have this issue and can't find the error!  Can you advise me, please, how you resolved yours?
Thanks
Paul
  • Nov 10, 2014 4:00 PM UTC
@Isabell:
Can you please share your solution here? It would help us others facing the same problem a lot.
@Hairy:
Have you found a solution yet? If yes, could you please also share? Thanks!
Four/five years later, this issues is not fixed . Someone knows why ? How can we fixe it ?
fmelizard
Forum|alt.badge.img+22
  • Dec 28, 2017 4:41 PM UTC
Hi @dimitri_veremes, are you seeing this error in your workspaces? If so, are you able to share the full log file?
fmelizard
  • Jan 12, 2018 6:23 PM UTC
