Oracle spatial writer in update mode.
  • Aug 23, 2013 9:48 AM UTC
  • 6 replies
  • 89 views
I am trying to update a geometry of a feature stored in oracle spatial. I've set the writer mode to UPDATE also I've mentioned the key columns (combination of four colums is unque).
The workbench executes without giving any error, the log shows that it has written fatures but the geometry column does not change.
Please suggest if I am missing anything in this.
Regards
IMRAN
fmelizard
Forum|alt.badge.img+22
  • Aug 23, 2013 11:25 AM UTC
Hi Imran,
Have you specified the target geometry column name? and made sure the update geometry contents is set to yes?
Itay
  • Aug 23, 2013 11:32 AM UTC
Yes Itay, I did that..
fmelizard
  • Aug 23, 2013 11:42 AM UTC
And the writer on none? Did you refresh the viewer?
  • Aug 23, 2013 11:48 AM UTC
Yes I Did..
And I am checking the output in the database itself.
fmelizard
  • Aug 23, 2013 11:57 AM UTC
A database also needs to be refreshed, but my guess is that you are doiing that too?
mmm I am running out of ideas then.....since you mention that the translation is succesful  I find it hard to believe that the update is not taking place.
I have many workspaces updating oracle data on a daily basis and it works like a charm.
Can you  provide more detalis? (log filsnap shot)
  • Aug 27, 2013 8:16 AM UTC
Hi Itay,
The problem was with the database server,
Thanks for the reply.
