Oracle Reader Grayed Out in Reader Gallery
  • May 15, 2013 8:16 PM UTC
  • 115 views
sdepriest
Forum|alt.badge.img+9
i'm stumped...
I have FME Workbench installed on 2 different machines.  On one machine the Oracle readers are enabled and available to be chosen and on machine 2 they are grayed out and disabled.
Yes there is a dot in the Licensed column of the Reader Gallery on both machines, so I believe I am licensed for it.
I have the Oracle client installed on both machines.
Machine 1 is Windows 7 64-bit.
Machine 2 is Windows Server 2008 R-2 64-bit.
How do I "enable" the Oracle readers on machine 2?
on Machine 1 the Oracle client was installed first, then FME 2013 SP1.  On Machine 2, the Oracle client was installed after FME 2013 SP1 was already installed.  Does that matter?
Sarah
  • May 15, 2013 10:39 PM UTC
Hi Sarah,
one possible reason is the difference of target platform (32-bit or 64-bit) between FME and Oracle client. Also look over this point.
Takashi
sdepriest
  • May 16, 2013 1:41 PM UTC
I found this article:
https://safe.secure.force.com/articles/How_To/32-bit-vs-64-bit-FME-support-and-Formats
And it says "Also to get at the Oracle databases we require a 32 bit Oracle client ".  I have the 64-bit Oracle client installed.
I'll get the 32-bit client installed and post back with the results.
Sarah
  • May 16, 2013 2:09 PM UTC
Match the bit version of the Oracle client to the bit version of FME.
E.g.
32bit Oracle Client = FME 32bit
64bit Oracle Client = FME 64bit
The local operating system and the bit version of the Oracle database has no impact. I also learned from Safe that you can have both 32 and 64 bit FME working with 32 and 64 bit Oracle clients on the same machine.
