ORACLE Reader: Failed to parse MapInfo Symbology string.
  • Jan 10, 2013 11:40 AM UTC
  • 81 views
fmelizard
Forum|alt.badge.img+22
I try to convert an Oracle Spatial table to MapInfo .TAB.
There is an MI_STYLE column. The spatial table looks all right in a MapInfo linked table.
In the workbench I ticked ' Apply MapInfo Symbology' and set the Style Column to MI_STYLE and Index Column to MI_PRINX (as they are in the database) n the Oracle Spatial Object Parameters panel.
However I get this eror message for all the objects and the style of all the objects in the output MapInfo table are the same (default):
ORACLE Reader: Failed to parse MapInfo Symbology string.  String was `Pen( 2, 2, 32768 )  '
All the objects are lines and polylines.
Does anyone have an idea why FME cannot parse the symbols?
davideagle
Forum|alt.badge.img+21
  • Jan 10, 2013 12:21 PM UTC
I'd recommend that you take a look at the contents of the MI_STYLE column in a bit more detail to make sure there are no corrupt values in there, no blanks etc. Presumably when you view the data in MapInfo you see all the appropriate styles as read from the MI_STYLE column?
There's not much on FMEPedia about this because its relatively new, in the old days you had to manually parse the MI_STYLE attribute with a set of transformers.
http://fmepedia.safe.com/articles/Error_Unexpected_Behavior/Oracle-reader-error-ora-00904-invalid-identifier
I'd also make sure that you are using the official MFAL Writer, rather than MITAB, though the error does point to the Reader as the issue.
http://fmepedia.safe.com/articles/FAQ/What-is-the-difference-between-the-MFAL-and-MITAB-Readers-and-Writers
fmelizard
  • Jan 10, 2013 5:01 PM UTC
Oh, those evil spaces!
`Pen( 2, 2, 32768 )  '  fails,
`Pen (2, 2, 32768) ' is working.
Thanks a lot for the tips, Dave.
You saved me the time to create a custom transformer that processes the MI_STYLE values :)
davideagle
  • Jan 10, 2013 8:28 PM UTC
It had to be the spaces, it always is! Check out my first post to this forum... spaces are always tripping me up, so I always look there first... except in this case of course!
https://safe.secure.force.com/AnswersQuestionDetail?id=906a0000000cZy5AAE
fmelizard
  • Aug 6, 2013 4:34 PM UTC
ORACLE Reader: Failed to parse MapInfo Symbology string.  String was `Pen(12,2,13421772) Brush(2,16764057)'
... Last line repeated 2499 times ...
I think I change back to the old day method
