Oracle Reader - Different handling in null columns in an aggregate function in 25.1 and 25.2
  • Jan 20, 2026 10:23 AM UTC
  • 5 replies
  • 242 views
max_h
Forum|alt.badge.img+39
I just updated to version 25.2 and my oracle reader is failing and throwing this warning (not an error):
An error occurred while fetching from query `SELECT a.*** FROM *** a' : OCI_SUCCESS_WITH_INFO: ORA-24347: Warning of a NULL column in an aggregate function
Which causes Translation FAILED with 0 error(s) and 1 warning(s) (0 feature(s) output).
My colleague tried the same on version 25.1 and whilst he also gets the warning his translation does not stop and he gets all features to work with. (As did I before my update)
Ignoring the fact that the view should be fixed, is there a way to continue the translation with all features? Troubleshoot option Ignoring failed readers simply skips the reader and thus returning zero features.
Furthermore I did see a few changes regarding oracle in the changelogs but I could not pinpoint which one is referring to this problem.
Best answer by desiree_at_safe
Hi ​@max_h! You’re right! This is an unintended change in behavior, but it should be fixed in FME 2025.2.3.
Look out for that build on the Download page
  • Jan 20, 2026 11:05 AM UTC
You can try to replace the reader with a FeatureReader (not very likely to make a difference, but you never know), or a SQLExecutor (which should work, but it’ll most likely be slower)
max_h
  • Jan 20, 2026 11:55 AM UTC
Thanks for the suggestions, but sadly FeatureReader, SQLExecutor and SQLCreator are all writing to Rejected port with reader_error: ‘An error has occurred. Check the logfile above for details’ → ORA-24347: Warning of a NULL column in an aggregate function
max_h
  • Jan 20, 2026 2:19 PM UTC
I fixed the view, issue was that listagg() had a few null values as it seems, so I had to add a few ‘not null’ conditions.
Still wondering though, what changed between the FME versions in this regard as it definitly worked beforehand on 25.1
desiree_at_safe
Forum|alt.badge.img+24
max_h
  • Jan 26, 2026 6:45 AM UTC
That’s great news, thank you very much!
