oracle Query execution error
  • Nov 20, 2013 4:23 PM UTC
  • 164 views
farfar
Forum|alt.badge.img+12
Hi all,
I have this error with executing spatial query with FeatureReader :
2013-11-20 17:11:55| 1.0| 0.0|ERROR |Execution of statement `SELECT "PDL_SIG_GAZ".* FROM ( SELECT * FROM "AMR"."PDL_SIG_GAZ" A WHERE (MDSYS.SDO_RELATE( A.PDL_GEO, :bindingQueryGeom,'mask=ANYINTERACT ') = 'TRUE') ) "PDL_SIG_GAZ" WHERE 1 = 1' did not succeed; error was `ORA-29903: erreur d'exécution de la routine ODCIIndexFetch()
ORA-13236: erreur interne dans le traitement R-tree : []
ORA-13236: erreur interne dans le traitement R-tree : [Snapshot too old or Recursive fetch error]
ORA-13234: échec de l'accès à la table d'index R-tree [MDRT Table]
ORA-29400: erreur de cartouche de données
ORA-00942: Table ou vue inexistante'. (serverType=`ORACLE8i', serverName=`CEDRE', userName=`AMR', password=`***', dbname=`')
2013-11-20 17:11:55| 1.0| 0.0|ERROR |Execution of statement `%5' did not succeed; error was `%6'. (serverType=`%0', serverName=`%1', userName=`%2', password=`***', dbname=`%4')
2013-11-20 17:11:55| 1.0| 0.0|ERROR |A fatal error has occurred. Check the logfile above for details.
Any idea ?
Thanks an advance.
FarFar
fmelizard
Forum|alt.badge.img+22
  • Nov 20, 2013 4:40 PM UTC
Hi Farfar,
I am sure you can find the details of this error online,  from my experience it usually has to do with geometry validation and metedata (or lack of it).
Hope this helps,
Itay
  • Nov 21, 2013 7:39 AM UTC
I'm with Itay, this is purely an Oracle error.
You could try to drop and re-create the spatial index on the table, in case they are corrupt.
David
farfar
  • Nov 21, 2013 9:40 AM UTC
Hi David & Itay,
Thank you for your help. Effectively, the problem was the spatial index. I drop and re-create it and it works.
Farfar
