Oracle Non-Spatial Reader 8000 character limit
  • Oct 24, 2019 10:02 AM UTC
  • 6 replies
  • 140 views
adrian_farrell
Hi
Trying to read an Oracle table containing one (Oracle limit) "Long" datatype field
The field only brings through the first 8000 characters into FME (these are typically upwards of 9800 characters in this DB)
As an aside into Access (ODBC) it reads more (8135) but not all of the field
Does anyone have any idea how to bypass this limit and bring in the huge field?
Thanks
Adrian
Best answer by markatsafe
@adrian_farrell Try the JDBC reader in the SQLExecutor. I think this will return the LONG strings.
@adrian_farrell It seems the LONG is no longer recommended: https://stackoverflow.com/questions/3599211/oracle-long-or-clob
I would suggest trying the SQLExecutor
  • Oct 28, 2019 9:07 PM UTC
adrian_farrell
I have been finding the large number of posts dotted around the net warning that LONG datatype are very antiquated and inflexible (this is another example i guess)
Unfortunately i'm working with a propriety system and therefore cannot change the data structures
adrian_farrell
Hi Mark
Thanks for the info relating to JDBC however i cannot get it to read Oracle, each time i get the error that there is no suitable driver available. do you happen to know a way around this error please?
Thanks
adrian_farrell
Hi Mark
Thanks
Hi again
I managed to get it to extract the data (adding the JDBC for Oracle helps!) but it still truncates the output
Adrian
adrian_farrell
Hi again
Adrian
Thanks Mark, turns out the system we are using has implemented a method to self truncate the field and store it in a hidden overflow table in 8135 character segments. It was a red herring the way they represented this in the main table and the fact that they still rely heavily on the LONG data type
The JDBC reader has been a learning curve but one very worth while following, i'll make some good use of that!
Thanks again
Adrian
