oracle julian dates
  • May 31, 2018 2:59 PM UTC
  • 119 views
gio
Forum|alt.badge.img+15
Hi all,
This works in SQL Developer.
Why does this not work in a SQL Executor/Creator?
select to_date(736845 + to_char(to_date ('02-01-0001'),'J'),'J') t1,
to_char(to_date ('02-01-0001'),'J') t0
from dual
output:
T1 T0
31-05-18 1721425
Fme executor insists `ORA-01843: not a valid month'
which is totaly not true!
 It appears that the 'J', julian format is not recognised.
 Is this a error or am i missing something?
Don't suggest out of sql solutions, i wan't it to be done in the executor. Be aware i will issue demerits !! ;)  SQL answers required.
Greets an txia for your answers.
Best answer by david_r
I suspect this is related to how the client connection locale is set. I was able to reproduce the exact same issue from Toad, so I don't think this is something that's specific to FME.
I think you'll find that to_date() is much more reliable if you explicitly specify the date format rather than relying on assumptions made by the client locale setting. Try the following:
select to_date(736845 + to_char(to_date ('02-01-0001', 'DD-MM-YYYY'),'J'),'J') t1,
to_char(to_date ('02-01-0001', 'DD-MM-YYYY'),'J') t0
from dual
  • May 31, 2018 3:07 PM UTC
from dual
gio
  • May 31, 2018 3:15 PM UTC
Yup, that worked.
Tx.
I would like, upvoted your answer, but I seem not able to.
Tx, again.
gio
  • May 31, 2018 3:16 PM UTC
Yup, that worked.
Tx.
Tx, again.
ah now I can up-thumbs up you!
Here you go.
(almost lewd...)
