Oracle connection issue: 'DEC-MCS' is not recognized as a valid encoding name.
  • Dec 16, 2020 1:58 PM UTC
  • 84 views
Hi
My setup:
  • Mac OS Big Sur
  • FME(R) 2020.2.1.0 (20201130 - Build 20806 - macosx)
  • Oracle Client installed (Version 19.8.0.0.0)
Connection is set up correctly (for example giving wrong username I get error: Error connecting to Oracle database: message was `ORA-01017: invalid username/password)
And when giving correct credentials I get error:
ORACLE_AUTONOMOUS_NONSPATIAL reader: 'DEC-MCS' is not recognized as a valid encoding name.
Any ideas what to try?
steveatsafe
Forum|alt.badge.img+16
Hello @markopytsep​ ,
Can you expand on the system history.
I see a very new macOS, a very new version of FME, and newish version of the Oracle Client.
Has this configuration worked before for you on macOS (Catalina with older FME or older Oracle Client)?
Hi @steveatsafe​
No, this was my first try with MacOS and I didn't have time and resources to try other versions.
steveatsafe
@markopytsep​ Thanks. Are you able to connect to this database from other systems?
What type is the Oracle database (on-premise, Oracle Cloud, or Oracle Autonmouse Cloud)?
Are you getting this error when adding a new Database Connection? (I think so).
