Once attributes are resolved, is there a way to remove the original (coded) attributes automatically?
nwse
In a SDE reader, you have the option to ‘Resolve Domains’:
In this example, this will take fields that have a domain, and create a new field with a suffix ‘_resolved’ and populates it with the descriptions from the coded values.
I.e:
The original field with the domain codes is ‘Accuracy_Spatial_Source’, while the ‘Accuracy_Spatial_Source_resolved’ are the domain descriptions.
Once the codes are resolved, I no longer need the original fields, is there a simply way to remove these automatically?
Sure, I can use an AttributeManager and remove them manually, however, it is not very practical or efficient when having more than 50 fields.
One way to somewhat ‘cheat’ is to use a BulkAttributeRenamer and remove the suffix ‘_resolved’ to basically ‘overwrite’ the original fields, however, this causes schema issues.
Another method I tested was using a PythonCaller and generating a list of all the “unresolved” fields, however, I could not find a way after to bulk remove the attributes from a list.
Has anyone figured out a way to do this?
hkingsbury
Forum|alt.badge.img+54
  • April 29, 2025
I’m not quite sure what you mean by schema issue with the BulkAttributeRenamer….
There is also the BulkAttributeRemover (and Keeper). Have you had a look at either of these?
nwse
  • April 29, 2025
By schema issue I mean, if you simply remove the suffix from the _resolved fields, this places the description values in the original field.
When you resolve domains, the original field is a ‘coded_domain’ type, while the resolved field is type ‘char’.
Therefore, if you use the BulkAttributeRenamer to strip “_resolved”, all the values are now going into a coded_domain field, thus causing schema issues when you go to write.
If you try to use a GDB writer, your translation will fail.
With BulkAttributeRemover, yes, this technically could be used but it’s the same method as the AttributeManager. I want to prevent doing it manually if possible.
hkingsbury
  • April 29, 2025
Are you using a dynamic writer (with a schema feature?) or are you using a standard writer?
If you’re using a schema feature, you’ll be able to break down the schema and adjust the field types from coded_domain to the desired type. This may require a bit of python to achieve smoothly.
If you’re just using a standard writer you can change the type under the user attributes tab
nwse
  • April 29, 2025
I’m just using a standard writer, however, if you use a feature writer, the translation is successful. Not sure what the difference is between a GDB Writer and a Feature Writer, but one works and the other does not.
To reiterate, I am simply just trying to find a fast and efficient way to remove the coded fields as I only need the resolved ones to be written. Changing things one by one is tedious and depending on how many coded fields a dataset may have, could take quite a bit of time, not to mention user error as well.
