OBJ Writer: writing trait "obj_group"
  • Jun 28, 2019 2:29 PM UTC
  • 95 views
Hello,
I'm trying to write an OBJ file with groups. Is it possible to do that? I tried creating an attribute obj_group and then use GeometryPropertySetter with Traits from Attributes. I also tried to Aggregate objects into groups but nothing works so far...
I've enclosed and example.
Thanks, Stéphane
sigtill
Forum|alt.badge.img+25
  • Oct 22, 2019 6:35 AM UTC
Hi @inspecteurgadge Like this?
You just need to set properties first, and THEN aggregate. The
  • Oct 22, 2019 9:15 AM UTC
Hi @sigtill thanks for your help! The problem is not in the Workbench, the problem is with the OBJ File Writer. I can see the trait in the Inspector like you but if you open the resulting OBJ file with a text editor, you can see that the groups are not written there.
sigtill
  • Oct 22, 2019 9:32 AM UTC
Ah, I understand. By looking at the documentation (also for FME2020) it seems its not possible. Best is to add this as a new idea here: https://knowledge.safe.com/content/idea/post.html?space=155 - or use another format that supports attributes. Which software do you want to read the obj file with?
