I have six 3D objects I want to place into my 3D PDF. The six objects between them make up two different "Things".
I'd like each of these Things to be controlled independently. Currently they share the same anchor/base, so if I try and rotate one, the entire scene rotates around a common centre.
Can this be done with 3D PDF and if so how?
Thanks!
Jonathan
