[NEWBIE] How do I do a basic KMZ to CSV conversion? Every attempt has resulted in blank CSVs.
  • November 21, 2017
  • 29 views
laurawatsafe
Forum|alt.badge.img+13
Hi @rsmart97, This article has an example of a similar workflow:
https://knowledge.safe.com/articles/56773/converting-non-spatial-and-spatial-data-to-csv.html
It walks through converting a Shapefile to CSV rather than KMZ, but the concepts should be similar for both formats.
If that doesn't help, could you please share a copy of the workspace you've built so far for converting KMZ to CSV? We could take a look and perhaps point you in the right direction for getting this working.
