NetCDF – problem with spatial reference
  • February 10, 2017
  • 10 replies
  • 76 views
Dear FME-users,
I’ve created a GeoTIFF-file based on NetCDF-data.
The problem is the spatial reference. A compare to OSM-data in the attachment shows you, that the GeoTIFF-file is not placed right. The second picture is from Copernicus and right placed.
Do you have an idea?
Thank your very much.
Best regards.
Konrad
Best answer by uba_kp
I’ve found a solution with „RasterGeoreferencer“ and I’ve used the expansion of the NetCDF input data. Now it works. Thank your very much @david_r.
  • February 10, 2017
Can you tell us
  • What is the SRS used in the NetCDF?
  • What is the SRS you've specified in the GeoTiff writer?
  • Which SRS is used in the GeoTiff from Copernicus?
  • February 10, 2017
Hi @david_r,
SRS used in the NetCDF is "LL84",
SRS I've specified in the GeoTITFF-writer is "LL-WGS84"
and Copernicus uses the SRS "EPSG:4326".
What I know is, that the long-degree-numbers oft the NetCDF are specific. Left to O° is like right to O°: 10°, 20°, 30° and so on.
Best regards.
Konrad
  • February 10, 2017
I'm not sure what you mean about "the long-degree-numbers oft the NetCDF are specific", but it doesn't sound like a regular LL84. Some meteo/climatological agencies use rotated spherical coordinates, could that possibly be the case here?
If you open the NetCDF in the Data Inspector, could you post a screenshot here of the netcdf_coordinate_variable{} list contents, that would be helpful.
  • February 10, 2017
Of course @david_r.
  • March 23, 2017
I haven’t found a solution for this problem yet. Maybe I’ve to solve this problem step by step.
First thing is that the NetCDF-Image is distorted in the Inspector. The resolution should have 700*400 pixel. I suspect that something is wrong with the distance but I don’t know how to change it. You can take a look in the attachment.
Does anybody have an idea what I can do?
Thank you so much. :)
  • March 23, 2017
If your NetCDF is distorted in the Inspector, it is most probably due a problem with your raster before it even hits the NetCDF writer. Send the workspace output to the Inspector instead of the NetCDF writer to verify.
  • March 28, 2017
Thank you very much for you answer @david_r. But it does not help. Do you’ve some more ideas what I can do? Thanks.
  • March 28, 2017
Not without analyzing the input data, the workspace and the output all together, which unfortunately takes more time than I can spare these days. NetCDF is a complex format that can be time-consuming to work with.
If you're completely stuck, consider contacting a local FME Certified Professional, many of them work as consultants and might be able to help you along.
  • April 25, 2017
  • April 25, 2017
Excellent, glad to hear you found a solution. Thanks for sharing.
