Naming an output file based on parts of the Readers/Tabs folder name and file name
  • Dec 31, 2013 8:37 PM UTC
  • 115 views
Is it possible to automatically name the output writer based on parts of the folder name the reader/TAB came from AND the name of the reader itself?
For example, This is the folder where the reader/TAB came from:
"KNKA208 CMA 028A Indianapolis"
And the readers/TAB name is "Authorized CGSA"
and I want the output to be named:
"A-KNKA208-028-Indianapolis-Authorized CGSA"
Thanks!
Joseph
  • Jan 1, 2014 11:02 AM UTC
Hi Joseph,
The FilenamePartExtractor transformer can be used to get folder name and file name of the source file from "fme_dataset" (a format attribute). You can then create the destination file name using the StringConcatenator, and use "fanout" option of the writer.
Takashi
