name of logfile
Hello.
Is it possible to change the name of the logfile a workbench writes by using a workbench in batchmode?
Regards Eduard
Best answer by takashi
Hi @walgram, you can specify a log file path in the command line with an option argument called LOG_FILENAME. e.g.
"C:\Program Files\FME\fme.exe" "C:\workspaces\myworkspace.fmw" --SourceDataset "C:\source\data.ext" --DestDataset "C:\output" LOG_FILENAME "C:\log\test.log"
Alternatively, you can create a user parameter linking to the Log File parameter in the Navigator window and then specify your desired log file path in the command line through the parameter.
Forum|alt.badge.img+19
  • March 5, 2017
femo
  • March 6, 2017
, this is another way to define a logfile name dynamically, using python:
You can of course use any other system parameter rather than "FME_MF_NAME". Or any other python function rather tham "time".
With the given settings, every fme run produces a new logfile.
