Trying to convert some DGN multi-part text nodes into ESRI geodatabase annotation using FME2012 Build 12258
Currently I have the setting Advanced>Split multi test set to No and the file is going through a Geometry Filter - String Concatenator- TextAdder sequence.
But, I get the error :
"Invalid geometry type received for an annotation feature. Please split multi-part annotations using the SPLIT_MULTI_PART_ANNOS keyword on the reader to 'yes', or switch to classic geometry mode before attempting to write them to a Geodatabase"
How do I solve this to enable a multi-part annotation to be written to the geodatabase, and then also set the leading/line separation, please?
Thanks
Tim
