MSSQL Spatial Column with type 'geometry' does not exist in table
  • Oct 16, 2015 8:30 AM UTC
  • 6 replies
  • 260 views
I'm trying to use FMEObjects, particularly read, modify data and write back to MSSQL database and I'm hitting a strange behaviour in 2015 version. Maybe I'm doing something wrong but.. I managed to read data OK but when I'm writing back it complains "Spatial Column 'geometry' with type 'geometry' does not exist in table 'dbo.simple_test_data'. Please specify an existing spatial column to write to". As far as I'm concerned - I have specified - here's my writer directives:
Writer parameters: COMMAND_TIMEOUT=34
RETRIEVE_ALL_SCHEMAS=YES
SERVER=server
USER_NAME=fme_datastore_test
PASSWORD=***
WHERE_CLAUSE=
CLIP_TO_ENVELOPE=NO
READ_CACHE_SIZE=10
ASSUME_ONE_SRID_PER_COL=YES
EXPOSED_ATTRS=
SPATIAL_TYPE=geometry
SPATIAL_COLUMN=GEOM
Here's extract from the log:
0.1|INFORM|+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2015-10-15 16:28:03|   0.2|  0.0|INFORM|Feature Type: `dbo.simple_test_data'
2015-10-15 16:28:03|   0.2|  0.0|INFORM|Attribute(32 bit integer): `ID' has value `1'
2015-10-15 16:28:03|   0.2|  0.0|INFORM|Attribute(encoded: utf-8): `fme_db_operation' has value `UPDATE'
2015-10-15 16:28:03|   0.2|  0.0|INFORM|Attribute(string)        : `fme_geometry' has value `fme_polygon'
2015-10-15 16:28:03|   0.2|  0.0|INFORM|Attribute(string)        : `fme_type' has value `fme_area'
2015-10-15 16:28:03|   0.2|  0.0|INFORM|Attribute(encoded: utf-8): `fme_where' has value `ID = 1'
2015-10-15 16:28:03|   0.2|  0.0|INFORM|Coordinate System: `'
2015-10-15 16:28:03|   0.2|  0.0|INFORM|Geometry Type: IFMEPolygon
2015-10-15 16:28:03|   0.2|  0.0|INFORM|Boundary:
2015-10-15 16:28:03|   0.2|  0.0|INFORM|   Geometry Type: IFMELine
2015-10-15 16:28:03|   0.2|  0.0|INFORM|   Number of Coordinates: 4 -- Coordinate Dimension: 2
2015-10-15 16:28:03|   0.2|  0.0|INFORM|   (50,0)(50,50)(0,0)(50,0)
2015-10-15 16:28:03|   0.2|  0.0|INFORM|===========================================================================
2015-10-15 16:28:03|   0.2|  0.0|INFORM|FME API version of module 'MSSQL_SPATIAL' matches current internal version (3.7 20121025)
2015-10-15 16:28:03|   0.2|  0.0|INFORM|MS SQL Server (Spatial) Writer: Opening `fme_datastore_test' for write operation
2015-10-15 16:28:03|   0.2|  0.0|INFORM|MS SQL Server (Spatial) Writer: Read 3 DEF line(s).  Found 5 attribute(s)
2015-10-15 16:28:03|   0.2|  0.0|ERROR |MS SQL Server (Spatial) Writer: Spatial Column 'geometry' with type 'geometry' does not exist in table 'dbo.simple_test_data'. Please specify an existing spatial column to write to
2015-10-15 16:28:03|   0.2|  0.0|ERROR |A fatal error has occurred. Check the logfile above for details
2015-10-15 16:28:17|   0.2|  0.0|INFORM|MS SQL Server (Spatial) Writer: Closing `fme_datastore_test' . Write operation complete
What am I missing?
  • Oct 16, 2015 10:07 AM UTC
Hi
How is your table defined?
David
  • Oct 16, 2015 10:32 AM UTC
Hi David. Sorry forgot to mention the important detail:
CREATE TABLE simple_test_data(
ID int PRIMARY KEY IDENTITY(1,1),
GEOM geometry
  • Oct 16, 2015 11:14 AM UTC
What happens if you drop the SPATIAL_TYPE and SPATIAL_COLUMN directives? You're just using the default values anyway, so it should make no difference.
You may also want to use one of the FME dialogs to create a template for your directives, it can be a lot easier than starting from scratch. You can adapt the code posted here: https://knowledge.safe.com/CommunityAnswers?id=906a0000000d4mdAAA
Adapt it to use the destPrompt() (http://docs.safe.com/fme/html/FME_Objects_Python_API/fmeobjects.FMEDialog-class.html#destPrompt) function and see what it returns.
David
  • Oct 16, 2015 11:44 AM UTC
It still fails in the same way - I added
SPATIAL_TYPE and SPATIAL_COLUMN only because I thought they'd help. Ok thanks for the links. Maybe I'll try and write a unit test first and see if it works there. At the moment I'm just debugging a part of a complex system...
  • Oct 16, 2015 12:09 PM UTC
I tried the destPrompt() using FME 2015.1.1 and I got the following directives:
DestSPATIAL_TYPE,geometry,DestSPATIAL_COLUMN,GEOM
So it seems FME expects a prefix "Dest" on the directive names.
Here is the entire directive string as returned from destPrompt():
['RUNTIME_MACROS', 'FME_CONNECTION_GROUP,,NAMED_CONNECTION,username<at>server<solidus>database,SPATIAL_TYPE,geometry,SPATIAL_COLUMN,GEOM,DESTINATION_DATASETTYPE_VALIDATION,Yes,COORDINATE_SYSTEM_GRANULARITY,FEATURE_TYPE', 'META_MACROS', 'DestFME_CONNECTION_GROUP,,DestNAMED_CONNECTION,username<at>server<solidus>database,DestSPATIAL_TYPE,geometry,DestSPATIAL_COLUMN,GEOM,DestDESTINATION_DATASETTYPE_VALIDATION,Yes,DestCOORDINATE_SYSTEM_GRANULARITY,FEATURE_TYPE', 'METAFILE', 'MSSQL_AZURE_SPATIAL', 'COORDSYS', '']
David
  • Oct 27, 2015 2:05 PM UTC
Hi again. I just found a bug in our software that caused it to specify wrong spatial column name for MS SQL - instead of GEOM it passed 'geometry' hence the error. Sorry for trouble, everyone, turns out not an FME bug at all ;)
