MSLinks in DNG file and FME conversion to shape
  • Oct 6, 2017 7:19 PM UTC
  • 6 replies
  • 142 views
fmenco
I asked this question on this tutorial page:
https://knowledge.safe.com/content/kbentry/1533/index.html#comment-54869
and was advised to post a question on the forum. Unforunately, I can't provide a datasample.
I just wanted to know... Say, I have a DGN file, which was created with one of Bentley's software packages. And I wanted to transhorm that DGN file to a shapefile just like in the tutorial linked above, but also linked to that shapefile the same attribute table which was related to it in the Bentley software. I've noticed a "Linkage extraction " through MSLinks and Framme, in the reader parameter. What would happen if I joined an attribute table with a MSLink column to my shapefile geometry (a table origially linked to the DGN file in the software package), when I check MSLinks linkage extraction? Would FME automatically detect which MSlink in the attribute table relates to which feature in the shapefile?
EDIT 1:
If you check MSLINKS in the linkage extraction, it does seem to take a MSlink value, I'm not sure if it's the correct one. I tried with a small workbench, but how do I now proceed? What comes after a attrbuteexposer transformer if I want to create a shapefile.. I added the steps in the tutorial linked above, but the shapefile doesn't contain the MSLink attributes. The reader is a DNG layer.
danilo_fme
Forum|alt.badge.img+58
  • Oct 7, 2017 9:47 PM UTC
Hi @fmenco,
Could you send a sample DGN?
Thanks,
Danilo
fmenco
  • Oct 8, 2017 3:20 PM UTC
Hi @fmenco,
Thanks,
Danilo
No, I'm sorry I can't..... But usually, what should you do when you want to add the attributes in one file to a shapefile..? How do you extract them and add them to your writer (which in this case would be a shapefle)?
danilo_fme
  • Oct 9, 2017 1:08 PM UTC
Hi @fmenco,
On Reader select the option Parameters:
Select the MSLinks in parameter Linkage Extraction:
Add the Writer shapefile and select the option Copy from Reader.
In my test i used a transformer AttributeManager to mapping the attributes from Reader to Writer.
Please, write me if this explanation is necessary to you.
Thanks,
Danilo
fmenco
  • Oct 10, 2017 9:22 AM UTC
Hi @fmenco,
Thanks,
Danilo
Yes, this worked... thank you! I would always check MSLink linckage extraction, and I would see the MSlink, but I just didn't know how to add them to the attribute table! Thanks !
The system adds them as mslink_0... Do you perhaps know what mslink_1 and 2 mean? I also get those, but they don't contain a value...
danilo_fme
  • Oct 10, 2017 2:22 PM UTC
Hi @fmenco,
I'm happy that its works now! :)
About MSLink has a interesting documentation about mslink Documentation Readers and Writers
Thanks,
Danilo
danilo_fme
Hi @fmenco,
Thanks,
Danilo
