MS Excel - efficient way to create diagrams?
  • September 21, 2018
  • 9 views
As part of one of my workflows, I would like to create an excel spreadsheet that includes diagrams.
My current way to do it is as follows:
  • create excel file with diagrams manually,
  • update data within file during workflow,
  • automatically rename file and copy to output directory.
This works reasonably well for some cases but also poses problems. For example, I cannot figure out a way to dynamically change the range of the data referenced in the diagrams.
Is there a better way which I haven't thought of yet?
Thanks!
Hi @jakobrehbach
Are you writing to MS Excel using templates?
The article below goes through how to do this and writes out the raw data to a separate sheet, then the charts/tables are created based on the named range of that sheet. By this logic, I think this should work in your case as the data changes.
https://knowledge.safe.com/articles/34364/using-a-template-file-when-writing-excel-data.html
  • September 25, 2018
hollyatsafe wrote:
Hi @jakobrehbach
Turns out that the automatic update for pivot-tables was disabled in one of my template files. This led to my resulting tabels and diagrams not being updated when I opened the file...
