MS_ACCESS_JDBC memory issue.
  • Mar 10, 2018 12:12 AM UTC
  • 83 views
I can only use JDBC for my msaccess database in the office (no ODBC or MSACCESS DRIVERS in locked machine).. trying to load ~600,000 features causes the error : java.lang.StackOverflowError eventually..
tried changing as described here: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/msaccess_jdbc/msaccess_jdbc.htm FME_JVM_MAX_HEAP_SIZE variable, re-started FME, rebooted machine, doesn't seem to do any different.. I know I'm close.. I just don't know how to make this variable setting to add more memory to Java..
fmelizard
Forum|alt.badge.img+22
  • Mar 11, 2018 5:03 AM UTC
We'll see if others have better advice, but I've just learned you need to set both FME_JVM_MIN_HEAP_SIZE as well as FME_JVM_MAX_HEAP_SIZE for it to take an effect.
ravenkopelman
Hi @cesarp, you have likely encountered a bug; if you can share the source data with us it would be very helpful. The log file from a failed read would also be valuable. We will attempt to reproduce locally (tracked by PR#82699) regardless.
As a potential workaround, try setting an environment variable to increase the the Java stack size: JAVA_TOOL_OPTIONS=-Xss4M (increasing the 4 as much as needed to make things work)
