MongoDB Feature Reader
  • March 10, 2017
  • 33 views
bubblebeb
I am trying to use the FeatureReader to undertake a spacial intersect query against a MongoDB.
The feature hits the FeatureReader and the log states that it has connected to the MongoDB, it even states the projection it is in. It then just does nothing.
The MongoDB does not register any connections with FME.
If I use a MongoDB reader it reads the database find. It is just when I use the FeatureReader.
Does anyone have a similar issue with this?
I am using build 17259 as the RC Desktop version.
fmelizard
Forum|alt.badge.img+21
  • March 11, 2017
Definitely sounds like a bug. I'll alert the team.
trentatsafe
  • March 13, 2017
Hi @sebkingsley,
I am sorry to hear about this issue you are having with FME.
We have tested this with our database, and the FeatureReader seems to be working with MongoDB. We performed an 'Envelope Intersect' and a 'Intersect', both of which returned features as would be expected.
Is it possible we could have you create a support case? This can be done by visiting the following link:
https://www.safe.com/support/
Kind regards,
Trent
