Missing *.so files in the plugins folder
  • Jun 29, 2021 2:30 PM UTC
  • 64 views
i have installed the FME Server Version 2021.0.3 with Docker. I´ve imported my Workspace successfully , but it runs into lot of warnings and it failed. These warnings are consisting of a lot of files, which could not be found. Why these files are missing and how could i fix these warnings.
best regards
tim
Hi @andylicht​
Did you have debug logging turned on when you published the workspace to FME Server? I would recommend turning that off if so, and re-publishing and see if you still get warnings. If the workspace is running successfully, I wouldn't be too concerned about the warnings.
Screen Shot 2021-06-29 at 1.00.25 PM
If log debug wasn't the issue, are you using your own engine image, or Safe Software's engine image?
  • Jun 30, 2021 7:20 AM UTC
Hi @jlutherthomas​ ,
the dbug options is disabled. We are using this docker image: https://s3-us-west-2.amazonaws.com/safe-software-container-deployments/index.html?prefix=2021.0/2021.0.3/.
In my desktop fme everything seems to be fine.
best regards
