Missing coordinate system in Feature Cass in ArcSDE
  • Jan 9, 2026 11:59 AM UTC
  • 6 replies
  • 127 views
kanhan1
I am writing data to Esri ArcSDE in FME Form and have tested using both CoordinateSystemSetter and Reprojector to define the coordinate system. However, when I open the feature class in ArcGIS Pro I get a message that the coordinate system is missing. Has anyone had similar experiences?
nielsgerrits
Forum|alt.badge.img+67
Did you create the featureclass using fme of are you inserting into an existing featureclass? Because coordinatesystem is defined at featureclass level.
kanhan1
  • Jan 9, 2026 12:18 PM UTC
I created the feature class using FME Form.
nielsgerrits
What version FME? Which coordinatesystem? Is it possible the system is known by FME and not by ArcGIS Pro?
kanhan1
  • Jan 12, 2026 6:47 AM UTC
Have used FME Form 2024.2. The coordinate system is EUREF89 UTM 32 (EPSG:25832).
It's almost the same issue that you find in this post: https://community.safe.com/transformers-9/how-can-i-change-the-name-of-name-of-the-epsg-25832-coordinate-system-from-nutm32-to-etrs-1989-utm-zone-32n-398
In my case, I write to SDE, and I get a message that there is no coordinate system in the feature class in ArcGIS Pro.
nielsgerrits
I have no solutions, but I would use sql to check what crs is actually written.
You’ll need SDE_layers and SDE_spatial_references.
If something is missing, maybe FME is not allowed to write in SDE_spatial_references?
daveatsafe
Forum|alt.badge.img+24
  • Jan 14, 2026 3:45 PM UTC
Hi ​@kanhan1,
Please try using the EsriReprojector with both source and destination set to your desired coordinate system. This will ensure that the data is tagged with an Esri-compatible coordinate system for ouput to SDE.
