Migration Oracle to SQL Server
  • Aug 22, 2017 6:13 PM UTC
  • 10 replies
  • 116 views
danilo_fme
Forum|alt.badge.img+58
Hello,
I would like to do a migration between Reader ( Oracle - No Spatial ) to Writer ( SQL Server ).
The question is: Its possible to migrate all from Oracle ( primary keys, foreign keys, indexes , views ) to SQL Server?
Thanks,
Danilo
Best answer by erik_jan
Hi @danilo_inovacao
Yes, I believe that is possible. But certainly not easy.
The data and tables will be straight forward using a reader and writer.
Information about the other objects can be read from Oracle (e.g. from data dictionary tables like all_constraints, all_indexes etc.).
The next step would be to create SQL statements from that information to be executed by FME or by the SQL Server client.
The default SQL Server writer is not likely to support all these objects.
erik_jan
Forum|alt.badge.img+26
  • Aug 22, 2017 6:29 PM UTC
Hi @danilo_inovacao
Hi @danilo_inovacao
Agree: while indexes and primary keys can be set right on the Writer, constraints and foreign keys will need to be created with SQL statements. These SQL statements can be ran with SQL Server Writer SQL to Run Before Write or SQL to Run After Write. This task will definitely involve some Oracle SQL into SQL Server SQL translation.
danilo_fme
  • Aug 22, 2017 9:48 PM UTC
Hi @danilo_inovacao
Thanks @erik_jan for your help.
danilo_fme
  • Aug 22, 2017 9:49 PM UTC
Hi @LenaAtSafe, thanks your reply.
Has example to show this SQL Statements?
Thanks
Thanks
I don't have an Oracle example. Below is what I got from SQL Server (RightClick on the table > Script table as > CREATE To > New Query Editor Window). I had two tables - Tab1 and Tab2 - where Tab1.foreignID is foreign key for Tab2.id.
Tab1 CREATE statement:
USE [schemaTest]
GO
/****** Object: Table [dbo].[Tab1] Script Date: 22/08/2017 11:38:28 ******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
CREATE TABLE [dbo].[Tab1](
[id] [uniqueidentifier] NOT NULL,
[Comment] [nvarchar](50) NULL,
[foreignID] [uniqueidentifier] NOT NULL,
CONSTRAINT [PK_Tab1] PRIMARY KEY CLUSTERED
[id] ASC
)WITH (PAD_INDEX = OFF, STATISTICS_NORECOMPUTE = OFF, IGNORE_DUP_KEY = OFF, ALLOW_ROW_LOCKS = ON, ALLOW_PAGE_LOCKS = ON) ON [PRIMARY]
) ON [PRIMARY]
GO
ALTER TABLE [dbo].[Tab1] WITH CHECK ADD CONSTRAINT [FK_Tab1_Tab2] FOREIGN KEY([foreignID])
REFERENCES [dbo].[Tab2] ([id])
GO
ALTER TABLE [dbo].[Tab1] CHECK CONSTRAINT [FK_Tab1_Tab2]
GO
USE [schemaTest]
GO
SET ANSI_NULLS ON
GO
GO
[id] ASC
) ON [PRIMARY]
GO
GO
GO
Tab2 CREATE statement:
USE [schemaTest]
GO
/****** Object: Table [dbo].[Tab2] Script Date: 22/08/2017 15:05:41 ******/
SET ANSI_NULLS ON
GO
GO
CREATE TABLE [dbo].[Tab2](
[Description] [nchar](10) NULL,
CONSTRAINT [PK_Tab2] PRIMARY KEY CLUSTERED
[id] ASC
) ON [PRIMARY]
GOI guess it might be easier to create the tables with SQL to Run Before Write and then only populate them.
  • Aug 23, 2017 10:20 AM UTC
I would try to connect SQL server to Oracle, no ETL required.
  • Aug 23, 2017 10:21 AM UTC
I would make a connection to Oracle directly from SQL server. This way you do not need to worry about the data types.
danilo_fme
  • Aug 23, 2017 1:34 PM UTC
Hi @hcode, thanks your reply.
danilo_fme
  • Aug 23, 2017 1:35 PM UTC
USE [schemaTest]
GO
SET ANSI_NULLS ON
GO
GO
[id] ASC
) ON [PRIMARY]
GO
GO
GO
Thanks @LenaAtSafe, your examples were useful to understand me.
