I have come across some examples where FME 'appears' to change the names of levels which are read in from a dgn file. When viewed in Microstation and Bentley View (v8) features will be on a level called 'UT-UT-CAT_Survey_Underground_Unknown' but FME says these features come from a level called 'AR-AR-CEILING FINISH-Z'.
What is FME reading to get this alternative level name?
