merge multiple xml elements into a single attribute
  • May 8, 2018 2:48 PM UTC
  • 384 views
I have an attribute of a feature called RTN_NOTES. It contains free text stored in an xml structure as below.
I need to merge the values of the <Run> element entries in to a single output text attribute(varchar). I have tried to use the XMLFlattener feature, but this seems to only return the contents of the 1st <Run> entry.  Any help would be appreciated. Thanks, Michael (FME Newbie)
<Section xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation">
<Paragraph>
<Run FontWeight="Normal" xml:space="preserve">I visited Joe Bloggs to discuss how he feels things are going.</Run>
</Paragraph>
<Paragraph>
<Run FontWeight="Normal" xml:space="preserve">Joe is worried about his situation.</Run>
</Paragraph>
<Paragraph>
<Run FontWeight="Normal" xml:space="preserve">I have suggested a follow up meeting.</Run>
</Paragraph>
</Section>
  • May 8, 2018 3:34 PM UTC
Hi @michaelpralph, if you set "Section" to the Elements to Match parameter in the XMLFlattener, it creates a list attribute called "Paragraph{}.Run", which stores values of all <Run> elements. You can then concatenate its elements with the ListConcatenator. Note: If there could be a case where there is just a single <Paragraph> element, additional consideration would be necessary.
Alternatively, you can also use the XMLXQueryExtractor with this XQuery Expression. This works regardless of the number of <Paragraph> elements.
XQuery Expression:
declare default element namespace "http://schemas.microsoft.com/winfx/2006/xaml/presentation";
//Paragraph/Run/text()
Many thanks @takashi, I applied the XQuery expression and it works perfectly producing a neat block of free text form the multiple Run elements.
Once again, many thanks.
