This week I got my first COU disk but cannot work out how to apply this update to my current .tab files. At first I tried just running the conversion to my current files as the output but this just overwrote the files. (glad i took a backup)
Are there some settings you need to tweek to append the files rather than overwrite? or do you need to process the data after it has been converted from gz to tab (although I assumed that the gz files contained invisible instructions that explains what to add and what to delete)?
Can anyone help me with this please because I assume it must be possible using FME. I have been playing around with different transformers (such as ChangeDetector) but am having no luck
