Map list values to attribute values
  • Oct 9, 2018 4:32 PM UTC
  • 169 views
sunsilk11
Hi I have used JsonFragmenter to read a json file and have ended up with a set of attribute values plus a list of values for each feature. I need to write the list to single attributes in a table based on the index. (see attached)
e.g Signalstatus[0] written to field STATUS_0
Signalstatus[1] -> STATUS_1 e.tc.
Any suggestion ?
Best answer by jdh
There is sadly no listFlattener transformer.
You can however use the BulkAttributeRenamer with Regular Expression Replace
Text to Find: ^Signalstatus{(\\d+)}$
String: STATUS_\\1
EDIT: use the exact list name in the data, based on the png it would likely be ^Statuslist\\.Signalstatus{(\\d+)}\\.Status$
jdh
Forum|alt.badge.img+41
  • Oct 9, 2018 5:15 PM UTC
String: STATUS_\\1
geosander
Forum|alt.badge.img+7
  • Oct 9, 2018 7:12 PM UTC
Or use a ListRenamer followed by a ListKeyValuePairExtractor (on FME Hub).
  • Oct 10, 2018 9:34 AM UTC
String: STATUS_\\1
Good suggestion.
If you expose the list elements under a prior transformer (right-click on the list name > Expose Elements > Select List Elements), the BulkAttributeRenamer would expose destination attribute names automatically, for what it's worth.
