Manipulating the data of excel file with many sheets
  • Mar 9, 2018 4:15 PM UTC
  • 76 views
mario_bla
Participant
Hello,
I'm new in FME but have some basic knowledge. I am trying to fetch some data from excel file and use it for analysis and making graphical representations (charts) but I am stuck with the steps much prior to this analysis. Unfortunately, excel file is not very well organized nor structured so I'm trying to overcome this problems and I managed to read some amount of data in structured form.
What I'm having problem with is this: excel is organized in many sheet: first (main) sheet has summary data from all the rest of sheets and one column is hyperlink to a specific sheet which holds the data in more detail. I would like that after the running of the workbench I have the ability to choose the specific sheet for analysis based on list of sheets I have already obtained from hyperlinks in the main sheet.
I tried to figure this out for the whole day without success. I would appreciate any suggestions or pointers.
Thank you in advance!
jdh
Forum|alt.badge.img+41
  • Mar 9, 2018 6:04 PM UTC
I would consider using a regular excel reader on the main sheet only, and analysing it to determine which additional sheets (feature types) need to be read in, and then using a feature reader on the same excel file to read in that specific sheet.
fmelizard
Forum|alt.badge.img+22
  • Mar 11, 2018 5:24 AM UTC
This does sound like quite an interesting setup. If you could post a scaled down (data removed?) mockup Excel file, that might help others dig in.
mario_bla
Participant
  • Participant
  • Mar 16, 2018 3:14 PM UTC
Thank you both very much for your effort. Sorry for taking me so long time to respond - I wasn't able to use FME for the last several days. I have prepared some mockup file, as asked, so I would appreciate any help with this issue.mockup.xlsx
jdh
  • Mar 16, 2018 4:42 PM UTC
Here's the basic concept: excelreadsheetdynamically.fmw
The trick to remember is to enable hyperlinks when initially adding the main excel reader.
