Lowercase PostGIS table names
  • Jun 18, 2013 10:42 AM UTC
  • 14 replies
  • 306 views
Hello FME'ers
I am using FME 2013 SP2 to bulk load data into PostGIS 9.2 from Oracle 10 using a very simple workbench.  I can set the attribute names to lower case in the PostGIS writer (as well as create the GIST index, sequence and primary key) but I also need to set the table names / feature type name to lowercase.  I have several hundred tables to copy over and it would be nice to change case automagically rather than manually editing the workbench.
Any suggestions?
Thanks
Ross
  • Jun 18, 2013 11:31 AM UTC
have a look at the BulkAttributeRenamer.
David
  • Jun 18, 2013 11:40 AM UTC
Hi David
The BulkAttributeRenamer only works on All Attributes or Selected Attributes and not on the table name / feaure type name.
In PostGIS after loading my tables look like: schemaname.TABLENAME and the columns all have lowercase names.
I'd like my table names to be lowercase.
Ross
  • Jun 18, 2013 11:43 AM UTC
yes, I just realised that I had misunderstood your question :-)
There is no very easy way to to this, as far as I know, although it is possible to modify the .fmw file directly, since they are just regular text files. You could then do a search/replace of some sort to convert the table names.
You could even do it with FME, using a TextFile Reader/Writer and a couple of transformers, such as the StringSearcher and the CaseChanger.
David
fmelizard
Forum|alt.badge.img+22
  • Jun 18, 2013 6:10 PM UTC
And if you change the fme_feature_type attribute into lowercase? what happens then?
in FME 2014  it seems that StringCaseChanger work on fme_basename but only if  it is the selected attribute : doesn't change while in a "all attributes" stringcasechanger
Arnaud
ponceta
Forum|alt.badge.img+7
  • Feb 28, 2017 8:18 AM UTC
2017, this is still a bug. There's actually no easy way to lowercase feature types (table names and schemes names)
Not the BulkAttributeRenammer nor the StringCaseChanger work on the $(FEATURE_TYPES) parameter :
This is a mess since Uppercase postgis table and schema names are a nightmare for Postgis DBAs.
  • Feb 28, 2017 9:14 AM UTC
Here's a possible solution:
The trick is to use the SchemaSetter and set the output feature type schema definition to "Schema from schema feature" (the technique is documented here). The SchemaSetter also has a handy setting to exclude certain attributes starting with a prefix, you can e.g. set it to "SHAPE_" to exlcude SHAPE_Length, SHAPE_Area, etc.
Also use a StringCaseChanger to convert fme_feature_type to lower case.
Tested with FME 2016.1.3.2 and Postgresql 9.4. Both table names and attribute names were written in lower case.
ponceta
  • Feb 28, 2017 1:25 PM UTC
I solved my case using simple SQL queries to have it modified afterwards.
If you have many tables have a look at :
http://www.postgresonline.com/journal/archives/141-Lowercasing-table-and-column-names.html
Some sql queries to construct the sql instructions: (2 steps)
For attributes :
-- As David Fetter kindly pointed out, this looks cleaner, returns one record per ddl and is more psql friendly
SELECT  'ALTER TABLE ' || quote_ident(c.table_schema) || '.'
  || quote_ident(c.table_name) || ' RENAME "' || c.column_name || '" TO ' || quote_ident(lower(c.column_name)) || ';' As ddlsql
  FROM information_schema.columns As c
  WHERE c.table_schema NOT IN('information_schema', 'pg_catalog')
      AND c.column_name <> lower(c.column_name)
  ORDER BY c.table_schema, c.table_name, c.column_name;
And for tables :
-- lower case table names -- the psql friendly and more reader-friendly way
SELECT 'ALTER TABLE ' || quote_ident(t.table_schema) || '.'
  || quote_ident(t.table_name) || ' RENAME TO ' || quote_ident(lower(t.table_name)) || ';' As ddlsql
  FROM information_schema.tables As t
  WHERE t.table_schema NOT IN('information_schema', 'pg_catalog')
      AND t.table_name <> lower(t.table_name)
  ORDER BY t.table_schema, t.table_name;
Generates sql actions like :
ALTER TABLE public."SPRINT" RENAME TO sprint;
Can be run with pgAdmin (my way) or in a SQL executor (assumption) on FME afterwards.
Did the job for me.
  • Feb 28, 2017 1:32 PM UTC
For attributes :
And for tables :
Did the job for me.
Interesting solution, thanks for sharing.
taojunabc
Participant
  • Participant
  • Feb 28, 2017 2:00 PM UTC
Because SchemSetter is not able to properly maintain the original type of the attribute, so I think the use of Schema Reader is a better choice.
?Here, assume that your attribute's count will not exceed 101. For the sake of simplicity I have specified attribute.name{0}~attribute.name{100} in StringCaseChanger.
taojunabc
Participant
  • Participant
Because SchemaSetter is not able to properly maintain the original type and order of the attribute, so I think the use of Schema Reader is a better choice.
  • Feb 28, 2017 2:41 PM UTC
Excellent point! I converted your reply to a proper answer for increased visibility.
taojunabc
Participant
  • Participant
  • Mar 1, 2017 1:12 AM UTC
@david_r Thanks.
In fact, In the current PostGIS Writer (FME 2016.1.3.1), Whether or not to choose "Lower Case Attribute Names", as long as it is in Dynamic mode, all the attribute name is converted to lowercase.
I was in FME 2016.0.1.2 found this problem, And talked to @takashi about it, I tested the FME 2016 1.3.1 and FME 2017 Build 17254, But it seems that the problem is still not resolved. So now it is more difficult to change all attribute names to uppercase. Currently to achieve it, @nono said is a good way.
ponceta
  • Dec 3, 2020 2:04 PM UTC
4 years later a much nicer way to do it fully on FME side :
illustration
Using feature reader and feature writer :
Select desired tables with a feature reader, expose fme_feature_type, change case in the schema AND in the features, use a postgreSQL or postgis feature writer.
With this fully dynamic approach you can get data and data structure from A to a datastructure of your own B following some of your customizations (schema modification, table lowercase, ...)
My lonely regret is the way to embed connection parameters which is much easier in standard readers and writers.
