Looping works when "run to this" but not when running the entire workspace
  • Mar 5, 2025 2:28 PM UTC
  • 172 views
akesoderqvist
Forum|alt.badge.img+8
A colleague and I are working on a script for a client. In the script, we have a simple custom transformer that performs a loop to match some attributes in the correct order. Its basically just a feature merger with a loop:
If I run the entire workspace the loops get stuck and keep iterating forever. However if we run the workspace with for example "run to this" far down the stream, it has no problem and the custom transformer finishes after a few seconds.
Does anyone have a clue why this is happening and what we could do to prevent it?
Best regards
Best answer by akesoderqvist
Hi, ​@akesoderqvist.
Thanks for posting to the community! Thanks for explaining the issue in detail. Are you able to detail how you setup your loop?
Thanks!
Hi, sorry for my late answer. We solved it, just by running the workspace on another computer it worked without any issue, then it worked on the orginal computer aswell after just re-saving the file. Have no idea what the error was, but im glad it works now :) Seems like it should be some kind of cache problem then? but i did purge all temporary data, run without feature caching and so on before without any luck.
Thanks for reaching out.
ali-safe
Forum|alt.badge.img+24
  • Mar 6, 2025 5:52 PM UTC
Thanks!
akesoderqvist
  • Mar 11, 2025 7:01 AM UTC
Thanks!
